I have a bunch of VCDs that were authored using the VCD header trick. I used these with the Panasonic RV32 and they worked great. However I find the panasonic to be real finicky on CDRs.. Now I would like to convert them to SVCD and use another DVD player. I did some searching and can't find any guides. They don't need to be standard SVCDs, XSVCDs are OK. Can someone point me in the right direction?
Thanks,
Tim
Let me get this straight: You want to convert to MPEG-2 for SVCD. This is just a hunch, but why not go to the Convert section and look for the heading Convert to MPEG2 SVCD?
Hello. -
Here's a guide for extracting the mpeg from the VCD: https://www.videohelp.com/forum/viewtopic.php?t=141726&highlight=rip+vcd
Only thing I don't know is if you then need to undo the header trick by multiplexing the new mpeg to mpeg2, essentially running the trick in reverse. You can ask the author of the guide, he's fairly well known around here!
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks. I did find that guide but I think I do need to find out how to reverse the header as it's not working just usind Isobuster. I'll email Baldrick.
Tim
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 10:42 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21 -
wireless Networking (router trick)
By stiltman in forum ComputerReplies: 0Last Post: 26th Mar 2009, 00:18 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 09:36
