I am framserving using DVD2AVI from 3 separate SVCDs. I have copied the avseq files from each svcd and have renamed them according to order (avseq01, avseq02, avseq03). They are copied in the same directory and when i load the first sequence in DVD2AVI it detects the other two as well, all is still good. I save the project and a d2v file is created and the audio demuxed to mpa. I have used gordian knot to create an AVI from the d2v file, and the film is fine, however, i noticed that the demuxed mpa file only contained audio from the first avseq. What can i do to framserve the entire audio from all 3 sequences?
The second matter is if the above solution of framserving the entire audio is not possible for some reason, then what process would i use to merge the three audio files to encode with teh d2v?
any help would be great, thnx. 8)
p.s. there is no delay reported by dvd2avi for any of the sequences.
