Hi there,
what should a hard drive's read and write speed be (MB/s), in order not to encounter dropped frames during capturing -even when capturing uncompressed AVI or Huffy - ?
i have the same problem. dropped 50 frames for 43 minutes long boxing match..is that good or bad or not bad. i have intel celeron 500 mhz. i don't know my hd's speed. used divx4 codec for video compression.
Using Huffy, I lose one frame per one minute. But that is because of my sound card (SB Live 5.1). If I turn off the option for "Change video clock dynamically to match audio clock", I won't lose any frames. But, of course, if I leave that off, my video will have audio desync occassionally. =|
Here's my specs...
AMD Athlon TBird 1.33Ghz
MSI K7 Master Mobo
256MB DDR Micron RAM
GeForce2 MX200
IBM Desktstar 75GXP 75GB 7200RPM (capture drive)
Maxtor 80GB 5400RPM
Windows XP
VirtualDub v1.4.7
SB Live! 5.1
<font size=-1>[ This Message was edited by: Jeomite on 2001-09-25 10:16:48 ]</font> -
IDE hard drives all suffer from the same problem, every now and again they carry out a thermal calibration. However I use IDE 7200RPM Maxtor drives and seem to be very good. I can capture through firewire 15 minutes without dropping frames.
The only way to overcome this is to purchase SCSI AV drives which are very fast indeed at around 30MB persecond, but these are very expensive.
I think you need to bear in mind, if this was a PAL capture you have dropped 2 seconds of footage out of 43 minutes. That is not too bad is it. -
I capturing on a i550 with 5400rpm drives. I drop some frames, but if the source file is in sync, I'll frame serve to make a svcd vid.
So you use a firewire also!? I do and would like to trade experiences. My Athlon 850 with a trial Win XP does not seem to do any better than Win ME. The picture if fuzzy/grainy and even jumps a bit. Any suggestions?
Looking for ideal converter
By xtof in forum Video ConversionReplies: 11Last Post: 4th Oct 2011, 18:34 -
Ideal Blu-ray Copy
By Quincyboy in forum Blu-ray RippingReplies: 3Last Post: 28th Apr 2011, 11:23 -
Ideal format to convert to
By The Monarch in forum Blu-ray RippingReplies: 2Last Post: 23rd Jan 2011, 21:35 -
What is an ideal upload/download speed for stable webcam use?
By yoda313 in forum ComputerReplies: 13Last Post: 17th Dec 2008, 18:12 -
New, ideal system - is it possible?
By TCIslandTime in forum DVD & Blu-ray RecordersReplies: 1Last Post: 31st Jul 2007, 21:45
