used DVDShrink to remove some of the foreign languages, and everything worked perfect... then I used Nero to burn it... everything worked perfect.... movie played in my computer just fine!!! was excited!! then put in my TV DVD player, and it wont play.... whats the deal? are there certain disks I have to use? i have a Toshiba SD-1600 or am I just gonna have to buy a new DVD player? cuz i hope not!!!
Results 1 to 17 of 17
NERO
Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Originally Posted by scott015Turn your head and cough.
1) Use DVD info to see if it is a video disc.
2) Right click on it and check its properties in windows.
I just inserted a data cd.
File system is CDFS, DVD info says its not a video disc.
Now I inserted a dvd I backed up.
File system is UDF, DVD info says disc is region 1,2,3 .....
3) If you had not already done so, check and see if you DVD Player is capable of paying burn DVDs.
Some devices that have no problem reading pressed DVDs cannot reliable read from burn ones. -
ok, i know i did dvdshrink right.... but maybe I did something wrong in nero... is there another program u reccomend I use instead??
but anyway, i did select dvd video instead of data dvd.... so i know I did that right... then I selected ALL the BUP, IFO and VOB files and "drag" to VIDEO_TS then thats it... i then did CD BURN under file menu
like I said, i then used my dvd player in windows and it played fine... but put in my TV DVD player and it says, please check disk
when I went to windows explorer and went to E: i then right clicked it... here is what it says
TYPE: Compact Disk
FILE SYSTEM: UDF
so anyone know if my dvd player is capable of playing these kind of disks... or is it something I did? its a Pioneer DVD-R disk that came free with my dvd burner... i also have a Pioneer DVD-RW that came with it... but I havent used it yet....
please help, im very discouraged... I paid all this money for the burner, i dont wanna hear I have to buy a whole new DVD player too... -
well i found this website on internet... so supposidly it should work...
i have toshiba sd-1600
so must be something I did wrong... anyone have any clues what I did wrong??? -
Instead of using the DVD video setting try these settings;
1)DVD-ROM(UDF/ISO)
2)No Multisession
3)ISO settings ISO level 1,ISO 9660 (Joliet is disabled)
All ISO restrictions Disabled(Allow path depths etc OFF)
When your new compilation window pops up make sure your settings are the same as above. Then click on the UDF tab and choose;
UDF partition type; physical partition
File system version; UDF 1.02
These settings have not failed me yet with either DVD-R or DVD+R. -
What version Nero are you using? If it is an older version(less than 5.5.10.15) you may want to go to Nero site and download the newest version, it works. I use version 5.5.10.20 and have had no problems with any of the DVD-Rs I've burned and played on my Toshiba SD-1600.
Some players are picky and requie that folder.--
Will -
Another thought, give DVD-Lab a try, it is free for 30 days and fully functional. A quick read of the "Quick Start Tutorial" (6 pages when printed) is all that I needed to get my first one done.
After a more thourough read, and on the website under "Tips and Tricks" I found it was easy to do "Switch Motion Menus". Excellent results.
Hope this helps.--
Will -
i have Nero 5.5.9.14
i did not do an audio file... how/what do I do there???
i would like to know what I did wrong before I just start waisting disks... they seem to be expensive.... what should I try and do now? -
also, laddydaddy... i checked, and those are the settings i already have, except for the joliet was checked....... wonder what the problem is... could it be the pioneer disk?
just my $0.02 worth...
my philips dvd stand alone will NOT play burned dvds unless they are at least 4GB or larger
it tells me to "check disk". this was solved by adding a "pad" file to the root of the DVD directory...(took a whole bunch of files and zipped em up, then renamed the zip to "dat"...never failed so far, even when making DVD slideshows... -
And I only use Nero to burn and they play fine in 4 DVD players I know of, Sony and Apex. I am using version 5.5.10.20
You need to go to www.ahead.de and download the new version of nero. it is a free upgrade for OEM and bought versions.
Good Luck
Roger -
Originally Posted by scott015--
Will
i just burned a dvd?
By just in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2008, 21:41 -
burned DVD can't be played
By linda.0p in forum DVD RippingReplies: 2Last Post: 19th Sep 2008, 13:18 -
no sound on a burned dvd
By kissy in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2008, 18:38 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
Cant read DV burned to DVD-R
By kunfuzed in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd May 2007, 05:20
