I am using TMPGenc in conjunction of converting an SVCD to DVD...I know this may be a dumb question, but can someone explain exactly what "bitrate" is. Is it just for audio, or is it for video too. And is it better to make it higher or lower, or what TMPGenc defaults it as.
From the glossary over on the left side (it's a great resource):
Bitrate or Bit Rate is the average number of bits that one second of video or audio data will consume. Higher bitrate means bigger file size and generally better video or audio quality while lower bitrate means lower file size but worse video or audio quality. Some bitrate examples in common video and audio files:
MP3 about 128 kbps (kilobits per second)
VCD about 1374 kbps
DVD about 4500 kbps
DV about 25 Mbps (megabits per second).
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54
