I created my first dvd with just basic text and one rectangle on the screen
I want to have a backround and music playing and maybe a second screen for chapter selection
Can someone help me out and please lead me in the direction of a forum or faq to answer my questions thanks
You can use drag n drop for [Compliant Files] if you want to use movie parts for background just hold down the shift key and drag the preview pic to menu background set time ect. For thumbs do the same without shift key. You can also import audio,bmp,mpg,ac3.mpa,mp2,wav and I think mp3 and set loop or time as you like.
And read HELP file very usefull.
Dd
http://www.dvd9to5.com/DVD_lab_Intro.htm
http://www.dvd9to5.com/DVD_lab_2.htm
http://www.mrbass.org/dvd2dvdr/
http://www.mediachance.com/(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Yes, and here is the DVDLab forum:
http://www.mmbforums.com/cgi-bin/forums/ikonboard.cgi?s=9f9b39353e762be14785a5c1068ae86a&act=SF&f=28
Also, make sure whatever sound you have for your background is *exactly* the same format as your movie sound -- all the sound in your project needs to be the same (so, for example, if your movie is AC3 5.1, so does your menu background sound have to be, and sampled at the same rate)."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
DVD / Blu-Ray Menu Creation
By motown01 in forum Authoring (DVD)Replies: 3Last Post: 7th Oct 2009, 15:15 -
Is there CD/DVD menu creation softeware that works?
By Djard in forum ComputerReplies: 11Last Post: 14th Mar 2009, 18:46 -
Questions about DVD importing and menu creation
By Reading Bug in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2009, 16:24 -
DVD menu creation
By andrewgerm in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2008, 16:24 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 19:27
