  1. Can someone help me please.
    I need a program that can convert WMV to MPG or AVI.
    I've tried TMPGENC but it doesn't work, I should have all the codecs, but not to sure as to which ones I need for the WMV files, I have the latest Media Player. So does anyone know what else I could do?
    Apr 2002
    The State of Frustration
    Interesting. Which version of TMPGEnc you have, and what error message do you get?
    Hello.
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    yes, why won't it work?
    I just converted a bunch of wmv files to dvd-mpeg with TMPGenc 2.59, the only issue I ran into was in selecting my file - I had to select "all files" under file types so I could select the wmv - once I selected it, it loaded and converted with no problems.
    If you can't get it to work directly, you could download Stoik Video Convertor (freeware, do a Google search) and convert from wmv to avi, then convert the avi to mpeg.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  4. i don't know it still not working, i guess the person who converted to wmv didn't do a proper job, anyways i guess i ll try to convert to avi first then to mpg
    thanks for you help guys and gals
    universe
    change file extension .wmv to .asf and open in tmpgenc
  6. Member Sooner02's Avatar
    I just tried this and Tmpgenc is saying the file can't open because it's unsupported.
