how long to burn 4.473.12mb at 4x with sony dru500ax
pentium 4 1.3
512mb
60gig hdd
should it take as long as 31 mins
dvd is
mahammad ali when we were kings
I dont think its burning at 4x
latest firmware 2.0f installed correctly
I have a 2X drive and burn my dvd in 23 to 27 minutes.. so no 4X don'T take 31minute (you got some problem with buffer)
It should take 15 to 16 minutes, if i remember correctly DRU500's are very picky on the media they like for 4x burning.
My suggestion is to change your media, and possibly update your firmware if necessary. -
I have a 500AX, and when I have 4x media that the burner likes, it takes 15 minutes.
mostly though I end up with 2x at about 30 minutes - I'll wait until the media cost drops further before I worry about speed.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Sony 500a same firmware as you 4x media (Full DVD) takes approx 15 minutes on +R
Your time sounds like 2X times.
I only use brand name 4X and they work fine at 4X...
I get the Verbatin 4X +Rs at best buy locally @ $29.99 for a 15 piece spindle.
Hope this helps
Cheers -
Originally Posted by TBoneit
media is RITEK 4X and have tried some more but still get same speed
I know there have been problems with this drive before as seen on various sites but i thought that the firmware updates fixed all this..
Does anyone know how to fix this
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
How long does it take to Burn a Blu-ray?
By DGenerateKane in forum Authoring (Blu-ray)Replies: 1Last Post: 6th Sep 2009, 05:01 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 02:12 -
Burning as Divx- burn time-why so long-alternates?
By Rik62 in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2008, 17:19
