Im capturing UK Sattelite TV, using my WinfastTV software to tune into the channels, and then using Virtual DUB to record. However the image is quite fuzzy - it however is not the card, because when I open certain programs or go to start/setting/control pannel/display - when the cpu is tested - the image become crystal clear for a few second... If anyone has a suggestion or has experienced this problem which may be easy to fix please reply or send me a quick email at dj_ministryofsound@hotmail.com
"come and get some f00l"
at a very rough guess, i'd say it had something to do with the tv tuner software. tried any other programs to do this?
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
I could try to get some more tuner software- im using a composite in...but the tuner software im using (winfastTV) has the option to use either Cable or Antenna. Im using Antenna, although the exact same results come up with both. What does a signal booster do and will it help my situation ? thankx in advance
"come and get some f00l" -
I have that same card. It had very poor video using the composite connection. I now use Sima Copymaster in the video input line and the composite video is very good. ........... harrymj3
Black Fuzzy Screen
By hfullerton@bcsd1.net in forum Newbie / General discussionsReplies: 1Last Post: 2nd Oct 2009, 14:16 -
FLV seems fuzzy on website
By expertadvisor in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Sep 2009, 13:57 -
Fuzzy Video using ADVC100
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 16th Jun 2009, 02:17 -
.mov to flash comes out fuzzy!
By crocwatcher in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 05:16 -
Capturing from my DV camcorder: artefacts with straight lines (fuzzy)
By hydrocynus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 14th May 2007, 20:56
