When I attempt to rip the film from .bin files, the result of the authoring stage is always the same ..Log says creting VTS etc then completes, but theres no vobs or ifo etc in the folder, its completely empty. If i use isobuster first to extract the mpgs first, I have no such problems (except it done it once)..Plenty of space on hardrives etc, so thats not a problem..Any Ideas? Its not much bother doing it the isobuster route, but the one touch solution is the whole reason I upgraded...
Thanx
Just to add to this, I gone back using the free version and autoring with maestro has ive found this a far more reliable method...i also noticed outputon those that succeeded the authoring step was noticably more widescreen than the source, is this normal?
What was your build number?
The image ripping is exactly the same in both version of the software so i am supprise that if you have issues with plus you don't with the free version.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
latest build m8..tried it on my pc and kids with same results....output of dvdmpgs are the same, just doesn`t want to output at authoring stage...all upto date besweet etc..
ok if you cut out a 10MB chunk of one of the mpegs(TMPEGEnc Mpeg tools will do this) and try that sample alone do you get the same issue? If so wanna ftp it to me?
KIPPERMAN32: I know you replied on https://www.videohelp.com/forum/viewtopic.php?p=554646#554646 but let me know if this has been fixed for you in the latest release please.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
An idiot and a video_ts folder...
By CitizenErased in forum Newbie / General discussionsReplies: 11Last Post: 24th Jan 2011, 17:00 -
VIDEO_TS streaming of folder playback
By pcexpress911 in forum Video Streaming DownloadingReplies: 1Last Post: 28th Jul 2010, 19:04 -
Create Video_TS folder using HCEnc
By marioval in forum Authoring (DVD)Replies: 6Last Post: 19th Jun 2008, 03:22 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 14:39 -
No Video_TS Folder..
By NatalieR in forum ffmpegX general discussionReplies: 1Last Post: 5th Feb 2008, 11:53
