I have an .avi from the internet and the accompanying subtitles as .srt file. I don't see no subs in the preview. To make sure I even set the position to 50. On the same note: Can I use subtitles in VCDs? I wouldn't mind if they were har copied into the mpeg, as the movie is letterboxed and leaves enough room in the lower black bar. Or can I encode the video and audio in ffmpegx and use another tool to make a SVCD/VCD with subtitles?
And yes, I rwad everything that was said about subs here...
Results 1 to 18 of 18
Guest
Guest
So, "burned into" means the subs will be part of the video? (If yes, are there options to have real choosable subs?) I just try it with using the CVD preset. What I note: There is not "author as CVD" option, so I use SVCD. And I don't have a "sub palette"?
Guest
so, that ifo/palette file thingy is necessary for subs? Because i didn't specify any and don't see no subs in the part of the movie that's already encoded...
Guest
I see an error:
font: can't open file: /Users/foo/.mplayer/font/font.desc
font: can't open file: share/font/font.desc
and no subs... sigh...
Guest
You mean the "Subtitles iso-8859-1.pkg"? Sure, I did everything as told in the readme... But I can do that again... (The last two updates only the app itself changed?)
Guest
You know what? The installer says:
"Subtitles for MPlayerOSX
iso-8859-1 encoding
This package contains a set of subtitles for use with MPlayerOSX. They will be installed to the directory /usr/local/share/mplayer/font."
But the software searches in:
"font: can't open file: /Users/foo/.mplayer/font/font.desc
font: can't open file: share/font/font.desc "
Maybe that's the problem?
Guest
As I wrote just above, the installer talks about "/usr/local/share/mplayer/font." But I can't find even "/usr/local/share/mplayer" after just running the pkg installer
If I look into the pkg I don't see anything I can use...
Guest
I already have that for mplayer OS X. Though I'm not sure what the guy meant when he wrote:
"If you have Mplayer OSX copy this file to /usr/local/bin"
"this file"? There is a folder with many files after the download:
codecs.conf
input.conf
MAN
mencoder
menu.conf
mplayer
readme.rtf
all I see in /usr/local/bin is mplayer, where does the "conf" stuff go?
And I see none of the font stuff there
Guest
Now it seems to work, thx
So is the mplayer you want people to get normally broken?
Guest
Will it be possible some day to have real subtitle tracks? Or is there any other software for Mac OS X that can make sub tracks for SVCDs?
Guest
Phewww...
The subs are not in synch
Looks as though they run slower then the movie, as far as I can tell. What to do?
Converting DivX to DVD, along with subtitles?
By guy24s in forum Video ConversionReplies: 2Last Post: 21st Jul 2011, 21:00 -
Subtitles on a DivX Files (how...)
By mjaeson in forum SubtitleReplies: 13Last Post: 14th Dec 2008, 00:33 -
Divx has subtitles and I want them permanently on an MPEG, but....
By darthvonpokemon in forum SubtitleReplies: 2Last Post: 14th Jun 2008, 12:45 -
How do you rip subtitles from a DivX file w/4 subtitles
By JoeBolden in forum SubtitleReplies: 2Last Post: 21st Nov 2007, 15:46 -
Burning Divx movies with subtitles?
By Hank Kinsley in forum SubtitleReplies: 5Last Post: 17th Jul 2007, 12:33
