i caputured full movie of size 987 mb. Now i want to compress the filesize of the moive around 300-350mb.I know this will affect the quality but how can i do it please help
thx
If this is for playing on a PC only then use a DivX codec with a low enough bitrate to achieve the filesize you want. Use vdub with the divx codec to encode the file. This will not play on a DVD player though. If you want to play on a DVD player you could use VCD or XVCD, the bitrate will depend on the length of the movie, this will look much worse than divx though with a filesize of 300MB
How to reduce filesize and to not lose too much quality?
By xxxThiefxxx in forum Blu-ray RippingReplies: 5Last Post: 9th Aug 2011, 09:48 -
my xvid videos are too big in filesize
By C-Royd in forum Video ConversionReplies: 1Last Post: 6th Aug 2011, 17:31 -
Reducing Filesize of .avi
By jonesb in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2009, 12:01 -
Reduce VOB filesize
By jacktorrance in forum Video ConversionReplies: 8Last Post: 14th Jan 2009, 12:34 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 20:22
