  1. okay
    I have used nero over and over
    had a coaster last night
    then i tried record max earlier
    not sure what version, got it from download.com
    trial
    another coaster
    anyway, i try using nero and everytime I click on "write" it then pops up a screen prompting me to save image file
    what the hell is this and why am I getting it
    I've never had this problem and have done over 100 dvd to 1 dvd-r
    I'm following the same instructions as always, here is the site I followed instructions from
    http://www.deano.dsl.pipex.com/backup/nero1.htm
    anyone know why????????
    thanks in advance
    my burner is the sony external usb/firewire that is dvd-r and dvd +r
  2. the selected burner that you are trying to use is an imager. When you get to the part to select your burner, select your actual burner.
  3. Human j1d10t's Avatar
    Feb 2003
    California, USA
    I had that same problem when I first got my DVD+RW drive. I even tried to choose my DVD burner as the recorder, but found out that my DVD burner was very new, and my version of Nero wasn't. My version of Nero didn't support my DVD burner. If your DVD burner isn't one of the choices, try upgrading your version of Nero.
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
