capturing direct to MPEG-2 DVD quality using AIW PRO 128 (old card-3drage chip) with MMC 7.6; audio is very "loud" at 48Khz 16 bit stereo. Also, sometimes when capturing, no sound is recorded, because "line in" is not "selected" anymore in "recording properties" with WindowsXP. I have tried turning the recording volume almost all the way down, and still the same thing. Audio too loud when burned to dvd with MF2. have tried using tmpgc to extract audio, besweet to convert to wav, normalize with goldwave, and same problems...anyone have any suggestions? also, any suggestions on how to make the "line-in" be "selected" all the time? I just recorded 2 hours worth of SG-1 with no sound!!![]()
thanx!
I had the exact same problem... what i did in the end was connect the audio directly into the sound card instead of having it go through the ati card's adapter. That solved the volume level bug.
RealaT Bytes, but that's what life is. -
That's no good. My SG1 came out great!
Anyway, check for bad wiring. The AUXILIARY is what my system uses, not LINE IN for the audio using the ATI AIW DDR32 and ATI MMC 7.7. You using the wrong one? By default, Windows may not show it in the sound area. Go to options, and make sure you can see AUX settings.
Funny. One Smurf helping another!Want my help? Ask here! (not via PM!)
thank you RealaT and Lordsmurf...i never woulda thought of that...I do not have a connector for the cable to go directly to the sound card, so I changed to AUX as the recording source, and not a problem since....
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 06:02 -
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 09:52 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 20:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 09:13
