i usually use nero to using dvd2one to take a dvd to dvdr
but having problems with that lately and thought I would try record max
can someone give me some instructions on how to use record max to put a dvd2one file on dvdr
thanks in advance
I just use the RecordNow Max Wizard and select data disc then put the VIDEO_TS folder and an empty AUDIO_TS folder into the record window and start burning, works every time.
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
How to record from a TV to a DVDR
By art_xer in forum DVD & Blu-ray RecordersReplies: 3Last Post: 11th Jun 2009, 09:12 -
Music Cd Burning Software - Record 3 cd's at the same time
By mn072065 in forum AudioReplies: 10Last Post: 5th Jun 2009, 09:02 -
Question how to change TV card max file limit of 4.1 GB
By jimdagys in forum Capturing and VCRReplies: 2Last Post: 25th Nov 2008, 07:47 -
Burning a DL dvdr problem
By efiste2 in forum DVD RippingReplies: 3Last Post: 16th Jul 2008, 15:06
