  1. Zuxius
    Guest
    I am a little frustrated.
    Program stops after resampling.
    As in other posts I have read
    However, there is no PC activity after failure and the BeSweet Version is 1.5b18
    The forums have been therefore little help, as most people fixed there problems via new BeSweet.
    My Comp
    P3 1Ghz 256Mb RAM
    60 Gig HD w/14 Gigs left
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Is this consistant with all your attemps with different source or is it just one particular source?
    You are welcome to send me a sample to analyse - check svcd2dvd.com FAQ for details on how to do this.
    CB
  3. Zuxius
    Guest
    Well, I decided to read real careful and I discovered that I missed a step of ISOBustering the SVCD. After that it seemed to do all it is supposed to....till it got to Multiplexing Stream, where it is hung up at present. The three files it created do not seem to grow in size anymore, and I am beginning to wonder if I should close the DOS Prompt mplex.exe myself. It seems it doesn't have the power to do it by itself. It has been some 45 minutes now, and the mplex is just sitting there. Last lines were
    INFO: [mplex] rough-guess multiplexed stream data rate : 2770000
    INFO: [mplex] target data-rate specified :10080000
    INFO: [mplex] Setting specified specified data rate: 10080000
    INFO: [mplex] Sectors = 89 Video delay = 13019 Audio delay = 13019
    INFO: [mplex] New sequence commences...
    INFO: [mplex] Video e0: buf= 273568 frame=000000 sector=0000000
    INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=0000000
    Even after writing this piece of poetry by hand, the files have still remained the same and the program hasn't budged.
    Zux
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
  5. Guest
    It actually worked after leaving it for like an hour. Mysteriously, it made that first DVDMPEG way too short. So I would consider that a success. Heheh, thanks for responding so well! Feel like I got my back covered.
