I have to decide between these two products for converting Analog Video to DV and then encoding to VCD using TMPGENC.
Dazzle Hollywood DV Bridge or Canopus ADVC 100. Which will give better DV quality ? Which products works without any problem ? I have read a lot of issues regarding Hollywood DV Bridge. Are they true ? Aren't there any issues regarding Canopus ADVC 100.
Dazzle DVB costs Rs.14550( US $296 approx ) in India.
Canopus ADVC 100 costs Rs. 18700 ( US $391 ) in India.
Is it worth paying $95 more for Canopus ADVC 100?
Are there people who are using DVB and Canopus ADVC100 who can compare and tell me which is a better product?
Please help me friends as I have to get one of these soon.
Vikram
vsenapati
I have used both and the Canopus comes out on top without a doubt. The Hollywood Bridge works great when it works. Had to return mine. The Canopus is bullet proof.
It is obvious that Canopus ADVC100 is far better than DV Bridge. If you
check "Capture card comments" section, you will find over a hundred
comments for the two devices.
On the other hand, if you can find DataVideo DAC100, it may be in the
same price range as DV Bridge. It seems that DataVideo DAC100 also has
a good reputation.
The comments on the three devices can be found in the following three links.
https://www.videohelp.com/capturecards.php?CaptureCardRead=Canopus%20ADVC-100&Search=Search
https://www.videohelp.com/capturecards.php?CaptureCardRead=Dazzle%20Hollywood%20DV-Bridg...&Search=Search
https://www.videohelp.com/capturecards.php?CaptureCardRead=DataVideo%20DAC-100&Search=Search
Ivy Bridge to be up to 199% faster than Sandy Bridge
By deadrats in forum ComputerReplies: 33Last Post: 7th Dec 2011, 13:06 -
canopus advc100 problems--any suggestions?
By esek64 in forum Video ConversionReplies: 3Last Post: 14th Aug 2010, 04:26 -
Fuzzy Video using ADVC100
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 16th Jun 2009, 02:17 -
Dazzle Hollywood DV Grounding Fix
By mk2000 in forum Capturing and VCRReplies: 6Last Post: 15th Apr 2009, 09:20 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 04:56
