Is there anyway to convert and compress a clip to a specific size?
Say I wanted a 20 meg video clip to be compressed into 5 megs exact... can it be done? any programs out there that would allow me to specify the size i wanted?
thanks
Any converter that lets you pick the bitrate will convert to an exact file size. The size depends on the length of the clip (in minutes) and the video and audio bitrates (in bits per second). In the Tools section there is a bitrate calculator which you can use to get the exact bitrate required for the length of your clip and the file size required. If you specify what type of file you're converting from and to, then someone can recommend an encoder.
Compress .AVI Videos To Have The Same File Size After Compression
By genoshaft in forum Newbie / General discussionsReplies: 11Last Post: 4th Jul 2011, 01:20 -
Want to compress to micro file size
By sum_guy in forum Video ConversionReplies: 6Last Post: 24th Feb 2011, 19:39 -
Are all advertized low profile pci cards under a specific size?
By GLE3 in forum Newbie / General discussionsReplies: 2Last Post: 18th Mar 2010, 12:19 -
Compressing to a specific file size?
By toxicquack in forum MacReplies: 6Last Post: 17th Oct 2008, 22:04 -
specific file size
By santino_avi in forum Video ConversionReplies: 4Last Post: 14th Jan 2008, 01:04
