  1. well I got this from JOEPIC's Guide, but that was for dvd copy. here are the steps for DVD COPY EXPRESS. You dont need to use Vobrator just IFOedit. all you have to do is got straight to step seven on his guide and follow my steps below.
    from step 7 on JOEPIC's Guide, open up ifo edit and press the OPEN button.
    then open the video_ts file from the DVDEXPRESS temp file and at the bottom there is the "VOB ID =1".
    all you have to do is delete the playback for that "ID=1" and SAVE then thats it. you dont need to use vobrater at all. the vob ID is always 1 that you have to delete when you use DVDCOPYEXPRESS. then you use your Burning program to write the dvd.
    when you are done with the DVD, close DVDEXPRESS and it will delete the temp file for you.
    If any body wants to write a DVDCOPYEXPRESS 321 intro remove guide, or get a hold of Joepic to add this to his guide please do so.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    even for "dvd copy 321" you dont need Vobrator - just two clicks w/ ifoedit does it .. only required for the first disk and you dont have to shut down dvd copy or use another program for burning..
  3. true! you dont need vobrator if you already know where the VOB ID's are.
    I was refering to the guide about using vobrator. he says you need it for finding the intro plus other id's you want to remove. also if you dont use other software for burning, you have to keep that archive text file in there.
    I diddnt have DVD COPY when I was first reading the guide so I was confused when I was using EXPRESS. So I rewrote this to try and make it easier for fellow DVDEXPRESS users.
    I have been using Ifoedit to disable the disclaimer and it works. I use DVDXcopy Express. When using DVDXcopy or Express the VOB ID in the Video_Ts file is always ID=1. I also have been copying the temp folder that xpress makes to have a back up of the back up. Xcopy wont let you copy the back up!
    I have been playing with some other programs and nothing is easier to use than Ifoedit and DVDXcopy Xpress. IMHO
    Bluepill
