  1. Hello, I have an MPEG 720x576 (I think that's the size) which is 813Mb large. Is there a utility to run that will automatically resample the file and make it <700Mb so I can fit it on a CD?
    Many thanks,
    Steve
  2. What for ? if your DVD Player can handle it, you can propably fit it as is, with maybe a little overburning to an 80min/700mb CDR, because when using VCD/SVCD Authoring, you can fit 800mb of file on it.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
