Everytime we make a backup, we must go from DVD-9 to DVD-5.
Are there any plans to make a DVD-9 for home authoring purposes.
I know that DVD-9s are pressed and cannot be burned. But wouldn't it be possible to press blanks and then have the burning laser do the same thing as the reader laser when the layer switches.
This would make life a LOT easier.![]()
Again...just a thought...
think blue as in Blu-ray Disc.
Dd
http://www.matsushita.co.jp/corp/news/official.data/data.dir/en020219-4/en020219-4.html(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Hey man,
That'd be amazing.
Only thing is:
I will have to get a new DVD player due to the new laser
and
When will this become mainstream?
Thanks -
Define mainstream? Blu-ray is out in Japan. I don't consider DVDR to be mainstream. Available, yes. Fairly low cost, yes. But not main stream. Remember there are still a LOT of people/homes out there that do not own DVD players.
As with all new technology it's going to take some time before the consumer decides if they want it. -
I think some one once said they burned 2 discs separetely and then super glued them together. Voila....dual layered disc.
Anyone stupid enough to try this I can not held responsible for damage that will incurr on any hardware.All I've got in this world is my balls and my word.....
and I don't break them for no one! -
Yes, factory-made DVDs are "pressed" not burned.
There will never, IMHO, be a burnable double-layer because the laser would destroy the top layer to get at the bottom layer.
Double-sided is a different question; all that takes is a laser-opaque layer between the laser-affected chemical layers. -
This subject keeps coming up - doesn't anyone use the search facility any more ?
https://www.videohelp.com/forum/viewtopic.php?t=151608&highlight=
I can't believe we've covered everything DVD already !
After a certain software (may not even exist but thought id ask!)
By SE14man in forum ComputerReplies: 16Last Post: 18th Oct 2011, 18:36 -
Need your thought's on these new SHM-CD Format Disc's?
By VEBouto in forum AudioReplies: 3Last Post: 16th Aug 2010, 05:19 -
Making Movies is More difficult than I thought
By Alextaylor in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2008, 01:16 -
Movies Everyone Liked, But You Thought were Crap
By Ironballs in forum Off topicReplies: 62Last Post: 4th Dec 2007, 10:07 -
Thought for the Day
By ahhaa in forum ComputerReplies: 2Last Post: 26th Jul 2007, 11:56
