Some subtitles are just too *&*&%^*& BIG!! I just can't stand it. I"m currently using VirtualDub & vobsob to make subtitles. It seems that i can change the color of the subtitles, is there a way to make the subtitles abit smaller? Please let me know!
So is your sub file .ssa?
Try openning that .ssa file in MaestroSBT and play with it in there. I believe what you want is to press the 'Timing' button and set the frame rate for IN and OUT. Then use the 'Edit & Preview' button and edit the font size and the position of the subs. I'm not sure what MainT (top?)and MainB(bottom? I have no idea) or Timer mean but just play around and I'm sure it'll start to make sense. Sorry I haven't used it yet so I'm only telling you what I've figured out so far. When you need to output the file, there doesn't seem to be an option for the .ssa format!?? I did see a button that allows you to feed the subs into the VirtualDub plugin from the Preview window (it's the little VDub icon in the upper right corner) but you need an NT based OS. You can try saving the new subs as .srt (for Subrip) and then use Subrip to open and convert them to .ssa again. Seems like a lot to do but it could work. Let me know how it goes.Happy to be here.
Reduce file size .
By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 15:08 -
Reduce file size
By windranger in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 10:18 -
Need to reduce video size to less than 195MB
By EMK5810 in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2009, 02:22 -
Reduce size of video
By von_25 in forum Newbie / General discussionsReplies: 2Last Post: 27th Sep 2008, 08:25 -
Isn't 360 x 240 a viable size?
By bneubert in forum ffmpegX general discussionReplies: 2Last Post: 19th Jul 2007, 19:03
