Hi, I have read and read. What is the best way to Rip and make a Svcd?
I tried DVDx over and over, it's always off far as audio and video sync.
Is it best to rip, then use the virtual Dub? Then go to the TMPGenc.
If I missed a post on the best way to go to start, I apologize.
I would suggest DVD2SVCD used with TMPGENC. It automates the process and is very easy to use. It makes great quality SVCD's, DVD's or VCD's
http://www.dvd2svcd.org/ -
After clicking [Open IFO] and selecting the proper file, are you making sure [Audio/Video synchronisation], [Detect progr. 24 Hz] and [Force 24 Hz] are all checked?
To elaborate more...
I rip my DVDs with Smart Ripper, encode with DVDx and burn with Nero.
After running Smart Ripper, open DVDx and click [Open IFO]. Select the proper file and you will be taken to your Input Settings screen. Make sure [Audio/Video synchronisation], [Detect progr. 24 Hz] and [Force 24 Hz] are all checked. After clicking [OK], you will probably get a warning of some kind but just click [OK] and go ahead with your Output Settings.
The resulting file should be in synch... -
I too, get excellent results with Smart Ripper and DVDX 2.2.
You can adjust the bitrate to fill the number of CD-R's you wish to use.
Easy ripping with DVDx 4.0
By Starbuck2010 in forum DVD RippingReplies: 41Last Post: 11th Dec 2013, 00:17 -
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 08:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17
