I had troubles with the audio creeping by the end of my 40 minute movie. By the end, the audio was 3 seconds longer than the video, making it look like a kung-fu movie.
This was because I was following a how-to guide in MacAddict which suggested you export your sound seperate from your QT movie (from iMovie).
First off, make sure you have iMovie 3.0.3 and QT 6.3, otherwise you'll end up with the problem anyway. Next, don't bother exporting your sound seperate as an AIF in long movies. It will sample at a different framerate as the video and you'll end up with longer audio than your movie.
I tried but couldn't get MissingMPEGTools to make me a good MP2 file from my Quicktime movie (dropping the whole idea of using the AIF file altogether). (Maybe someone has a suggestion there... I kept ending up with a 0KB file anytime I tried to run the .mov file through the audio extractor) So I used ffmpegx to pull the audio and video. I muxed them using MissingMPEGTools. That was the trick - using ffmpegx to pull the MP2 and the M1V files. When they muxed, they worked great, and the audio held through all 40 minutes flawlessly.
Again, if anyone knows why I couldn't pull audio from a QT movie in MissingMPEGTools, I'd like to know.
Results 1 to 1 of 1
Changing The Audio Of An AVI File "Language" {HELP COMPLICATED PROBLEM}
By Mr CMTS in forum EditingReplies: 1Last Post: 28th Nov 2011, 20:04 -
One deviant "Quicktime file". Is there a solution?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2011, 18:54 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 22:28 -
is there an free "anyfile to uncompressed/lossless" solution?
By squadjot in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2008, 14:20 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 19:49
