Hello everyone. I have ripped a vhs tape to an avi uncompressed file, and then used TMPG to convert to mpg. The resulting mpg is fine with no freezing for frame skipping. When I use Ulead's movie factory 2 to make a dvd from this video, the resulting dvd video will freeze for a split second every minute or so (like a small tear in the video I will see, or a slight hesitation in movement), sometimes a couple times in a minute. My dvd player reads r's and rw's and Ive tried the video on both types of media. The split second freezing seems to be random. Something in the authoring process is causing this. Has anyone come across this problem, or can anyone shed some light? Thanks!
Welp I just tried dvd-lab and it seems to produce fine results. The skipping and freezing is gone, so for some reason Movie Factory 2 can't do the job. I'm trying Movie Factory 1 just to see what happens.
For reliable authoring in DVD MovieFactory 2, I recommend that the Ulead MPEG.Now codec be used instead of 3rd party encoders.
Jerry Jones
http://www.jonesgroup.net -
movie factory 1 produces the same freezing up. Apparently tmpg and MF don't go well together.
I have a problem using Ulead DVD Movie factory including.AVI Files, the pro
By OggO1984 in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2009, 09:42 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 04:48 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 04:26 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 03:20 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
