Just splitting the video and audio?
If there is a problem with audio sync, is it a way to correct the problem by demutiplexing the file and adjust the audio?
For me, my encoder doesn't like to work with the sound. It gets all humped up. So, I split the file (demultiplex) it. Run the video through my encoder. Then after (multiplex) them back together.
Don't give in to DVD2ONE, that leads to the dark side. -
I don't think anyone just de-muxs, then muxs again. There are a lot of reasons to demux:
Several DVD authoring programs will only accept elementary (ie. de-muxed) streams.
Some encoders mux incorrectly resulting in auto padding which can REALLY increase the size of the MPEG (eg. 795MB MPEG but with auto padding -> 825MB).
To replace or edit the original/source audio.
etc. etc.
Conversion or demultiplexing of TRP files
By ranmamez in forum DVB / IPTVReplies: 2Last Post: 26th Oct 2011, 08:50 -
out of sync when demultiplexing
By calanda in forum Authoring (DVD)Replies: 5Last Post: 5th Aug 2010, 01:04 -
General Purpose Video Files
By AndyPerry in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2009, 22:27 -
I need an all purpose converter
By warlock110 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2008, 21:06 -
Best all-purpose format for DVD rips
By studawg66 in forum Video ConversionReplies: 5Last Post: 3rd Sep 2008, 11:49
