Hello.
I'm in a wierd situation right now and I'm wondering if this will work?
I have a bunch of .rmvb video files and I can't find a way to convert them.
So what I'm thinking is if there is a program that lets you capture video in Windows while you are playing a video file?
This is the only solution that I can think of...
Thanks!
Is there a program that can capture video with in windows?
What I mean is like recording everything that is happening. -
Is there a program that can re-capture a video file?
For example, when a video file is playing in windows media player, is there a program that can recaputre that file in a differt format? -
I just gave you the link....You simply highlight the window u want captured and it will create an avi file.
I tried that program and it doesn't work. It just captures a black screen with no nothing...
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
Can't Caputre MiniDVDs.
By menash07 in forum Capturing and VCRReplies: 1Last Post: 26th Jun 2010, 17:50 -
playing +R DL discs
By dan101 in forum Authoring (DVD)Replies: 13Last Post: 8th Jun 2009, 00:40 -
Playing with SnagIt
By solarblast in forum Newbie / General discussionsReplies: 7Last Post: 15th Nov 2008, 07:16 -
help with playing a file
By benjaminlieu in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2007, 23:18
