I am having a problem with an AVI file that I created in Premiere 6. When I attempt to encode it with TMPGE I get an error message that says something like "not supported file format". It is a DV AVI, captured from my Sony Digital 8 camcorder. ANy ideas what might be wrong??
Can you play them and watch whatever you captured ?
Go to Premiere 6.0's file information under File menu. select the file you have captured. What does it say there ? -
Did you ever try to use avisynth? There is a AVS patch that when ran will let TME... see AVS but it will not see AVI files
Just a LITTLE problem I ran into.
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 11:13
