When TMPGEnc extracts to a wav file for external compression sound pops are introduced in the wav file. I used de-mux to extract the original MP2 sound from the Mpeg and there are no pops so it must be the conversion that TMPGEnc uses to go from MP2 to WAV. Is there a resolution to this? I can recreate this issue at will on at least 4 of my video captures, I have not checked the rest of my video captures as of yet. Oh, and I was useing Toolame to compress so I went with the internal compression engine to verify it was not external and the internal compression also introduces clicks and pops. -Alex
If you want to decode MP2 --> WAV, you could try just using Winamp with the disk writer plug-in.
Regards.
Michael Tam
w: Morsels of Evidence -
I dont want a WAV file. I want a VCD encoded file which is why I am posting here to VCDHelp. I am not getting clean sound is my issue, not converting to wav.
It seems like this issue is also related to my Thunderbird processor. I can take the same mpg file and encode useing the same exact settings on a P3 and it will encode correctaly. Any one else having pops introduced when encoding on a thunderbird processor? -
What are you trying to do exactly??
Regards.
Michael Tam
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 14:11 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 16:53 -
pops or clicks in wav file
By johnsees in forum AudioReplies: 7Last Post: 30th Jan 2008, 05:08 -
aiff to mp2 audio conversion problem...
By huatnee in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2007, 11:52
