hiya everyone
i have been succesfully creating svcd for a while now with no problems using 2 cd's but recently a friend of mine has come across some divx movies on 1 cd that look stunning but when i tried to rip one it turns out all blocky and hazy looking no matter what bitrate i use.
so can you tell me what programs and codecs you people use to get a good quality divx on 1 cd and also what sort of settings ie(bitrate) u use
cheers
...........dave
You need to set your DivX decoder configuration to highest quality (accessible through Start-Programs-DivX-codec)
i have tried that but what codec r u using i am using the 5.03 codec that comes with the player i have heard that the older 4 version is better or is that a croc.
......dave -
DivX 5.05-adware
The latest DivX free versions (from 5.0 onwards ) stink for encoding-perfectly ok for playback. Adware versions are same as the Pro full versions and show very very few ads, i.e. they are as good as free!!The encoding quality is mindblowing as long as u know what ur doing. -
divx 4 will come out like crap.
divx 5.03 has bugs.use 5.05 pro with gordian knot. http://www.doom9.org/gknot-main3.htm
for 1 cd'ers it depends on the dvd if it will look good.most dvds you have to make it 2 cds for it to look close to dvd. -
just tried it and still looks crap if i have to use 2 cd's for a divx i might as well stick with the svcd's i've been making to start with,still it was worth a try.
cheers
everyone
.............................dave
Problems with conversions
By dkritso in forum Newbie / General discussionsReplies: 4Last Post: 28th Jun 2010, 01:18 -
mpeg-ts and .ts conversions
By nirbhayn in forum DVB / IPTVReplies: 3Last Post: 30th Aug 2009, 18:00 -
Help with multiple conversions
By Hoover40 in forum ffmpegX general discussionReplies: 1Last Post: 13th Sep 2008, 23:14 -
Best conversions for dvd
By atvmxr in forum Video ConversionReplies: 5Last Post: 22nd Apr 2008, 09:47 -
DivX conversions to DVD
By catricric in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2008, 07:21
