From History+ on website:
1.0.1259.17369
Quite a big release.
Bug fix: Noticable "stutter" where MPEGs are joined has been resolved.
New: The ability to choose Sonic Foundry SoftEncode as the AC-3 encoder instead of BeSweet. SoftEncode is no longer sold but some users tell me that they already have it so why can't they use it to encode the audio.....? Also you can get used copies from eBay and the like if you want. Why bother? Well SoftEncode produces very high quality AC-3 streams which are highly compatible with the DVD specs. NB: the trade off however is that SoftEncode is slow & will increase you conversion times considerably.
Thanks go to Gurm & TalynOne for their help in testing, SoftEncode syntax, and for suggesting this functionality in the first place!
New: Added PAL to the Menus preview. You now have (NTSC/PAL, 4:3, 2 VTS only). So if you are updating (and you fancy using menus) delete your old Menus folder & get the new Menu Pack (http://www2.svcd2dvdmpg.com/release/menus.zip). Extract this zip to your install (svcd2dvdmpg+) directory (using folders within the zip). Note, the menu pack is included in the current msi install.
New: For those having issues with the Auto Update feature. The ability to check for updates manually.
Babylon 5 Re-release on DVD5 ?
By Noahtuck in forum Newbie / General discussionsReplies: 7Last Post: 18th Jan 2012, 16:48 -
Firefox 3.5 final release
By pepegot1 in forum ComputerReplies: 1Last Post: 29th Jun 2009, 13:53 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
Did I release a virus on my PC?
By mn072065 in forum ComputerReplies: 11Last Post: 18th Aug 2008, 17:33 -
HQ DVD Covers Before There Release
By twiggy99 in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2007, 14:01
