I have been trying to create a DVD with DVDit PE but somehow I always get an error. I want to combine a video file m2v type with a 2 channel ac3 audio file. Everything goes well (menus, chapters,..) until I want to create the final DVD structure on my HD. Than I get an error message "build failed Unknown error (BRErr, 1)". Anyone know what I did wrong?
I am also using dvdit to auther with. I was having some problems with it to start with but then got them sorted out. here's how i do it step by step.
First take an avi file and put it into virtual dub and extract the audio from it then open tmpegnc and without using the wizard put in your avi file and your audio file then have it create your mpeg2 file as a system file not as video, you'll end up with 1 mpeg 2 file and import it into dvdit and it takes it no problems. how i do it anyway might not suit others but suits me and works for me.
Nero Error Msg - 'Prepare Session Failed'
By Dieseldog in forum Authoring (DVD)Replies: 0Last Post: 19th Dec 2011, 06:38 -
Error in Build 5000
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 9th Dec 2008, 13:25 -
Applescript error in Leopard build 9A527
By rbrakes in forum ffmpegX general discussionReplies: 14Last Post: 17th Dec 2007, 12:18 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:51 -
Error when encoding to mpeg using mencoder celticdruid build.
By freebird73717 in forum Video ConversionReplies: 3Last Post: 30th Aug 2007, 22:51
