Hello,
new troubles
i have an avi
the first step i used audiodub all good
then go to encode it useing tmpgenc and i get a box come up that says unsupported file
i tryed another program to convert it to mpeg and it gave me a box that said compressed audio cant be used with this program
i have never had this troubles can anyone help me??
8)
Results 1 to 10 of 10
open the file in g-spot (available in tools section to the left). then post the info for the audio and video that it shows you. with that info, we can probably help you.
I have seen this problem before - place your AVI file in a folder on your desktop only and try again.
When I try to open .D2V files that are too deeply buried in folders, TMPGEnc claims not to support them.
Just a suggestion that probably won't work, but still might be worth a try for all the effort involved.
Good luck!
CobraDMX -
Here's one for you (my appologies if it sounds too dumb)...but have you made sure it's not an XVid file? It would still say it's an avi...
Hello,
i tryed as suggested moving it to my desktop and that still didnt work
Next i used gspot this is what it says in those to sections asked
video format
codec
4cc xvid name xvid
status codec is installed
aspect 560x304
bitrate 825
framrate 25.976fps
duration 00h 50min 05sec
audio format
name 0x0055(MP3) ID'd as MPEG-1 Layer 3
codec is installed
bitrate 35 kb/s (67/ch x 2 ch) VBR LAME3.89
Fs 48000 Hz
so it is telling me here that its not a avi?
helllpppp -
open video file in gold wave and save audio as wav then use in tempenc. or if the file opens fine in vdub then frameserve to tmpgenc.
ahhhh...it IS and XVid then...
Since this is the case, you'll need to find the guide on the right hand side on the special way to set up TMPGenc to read XVIds properly...I had the problem, but after setting everything up, I'm fine. -
hello
i tryed the goldwav way no good
and vdub will not open it
ok trying the last post now if i can find the way -
What does virtual dub say when you open it ?
i know exactly what your problem is
email me and i will send you a prog that does it and a guide that helps
please help: unsupported mHz in Adobe 6.0
By chicagomama in forum EditingReplies: 5Last Post: 18th Oct 2010, 22:32 -
PSP saying unsupported Data.
By kumar66 in forum Newbie / General discussionsReplies: 7Last Post: 14th Nov 2009, 22:32 -
AutoGK: Unsupported audiotype! Here's what i tried.
By Moonwalker1982 in forum Video ConversionReplies: 1Last Post: 14th Feb 2009, 05:34 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 17:51 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
