I was just given some cartoons on vcd's with average to poor quality. Anyone know what I can do to improve the picture? What software is recommended?
Thanks!
I have serious doubts. Usually the rule is "crap in = crap out".
Try re-encoding in TMPGEnc.
Prasanna.*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
Thanks for responding! Ok, I have TMPGenc, now how do I go about
re-encoding?
Thanks,
Gary -
Try this guide: https://www.videohelp.com/tmpgenc.htm
your imput is the mpeg file you got. -
Try using the filters in TMPG to "improve" your picture. You can boost faded colors and try to sharpen the picture if it is too soft.
if the cartoons fill up your screen and you can live with putting black boraders all the way around it (thereby shrinking the picture), there is a guide that will take (using TMPGENC) the 352x240 and while keeping the actual overal resolution and put black bars around the movie.
Again, it is in the guides section and sounds like convert low resolution avi 320x240. The guide uses the tv show survivor as the example. Anyway, it should give you a good idea of how you would go about doing this. -
You have not specified your problem
If problem is pixelation use TV filter in Vdub
with I/Q (chrominance) either 3x3 or 5x5 average
If problem is blurring use sharpen filter in Vdub or through Avisynth or Sharpen Edge filter in TMPGEnc
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
