Hi.
I'm looking for dvd authoring software that will allow text menus but at the same time have the ability to have a motion background.
Example:
Text Menu - Like in Sonic DVDit where you have the ability to link chapter points to text in the menu where the text acts as 'buttons' instead of using 'thumbnails'.
Motion Background - Like in Sonic MyDVD where you have the ability to have footage (video/audio) looping in the background of the main menu.
Does anybody know of software that can do both?
I've tried Ulead VS7, Sonic MyDVD, Sonic DVDit, DVD Complete, and Pinnacle 8. None of these had the ability to do both text menus and motion backgrounds.
In case you're wondering, I have seen this done. I have a DVDR I bought off ebay and it had this exact menu (1 screen, motion background, text menu with chapters). The seller no longer sells on ebay and unable to contact to ask what the software was.
Thanks in advance for your help,
ChachiFace
Results 1 to 9 of 9
This does not sound too difficult, actually. I used Ulead DVD Workshop, and it can definitely do what you are describing.
Scheif,
Are you sure it has the ability to create motion background (video/audio) with text in the main menu linked to chapter points? I don't care for the 'thumbnails' or 'buttons' just simple text. The text should be modifiable (font & size).
What version of Ulead DVD Workshop do you recommend?
Thanks for the response,
ChachiFace -
Yes, it can. I have used DVD Workshop 1.3 to do this before.
I have also done it with DVD Maestro.
Scenarist will also do it, of course.The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be. -
DVDLab will allow you to do it. Import a prepared clip and place it in the menu background. Use the text tool in the program or create text in a graphics and import it for your menu buttons.
And a thirty-day no-holds-barred trial to boot. It's listed in the Tools section [https://www.videohelp.com/tools?&orderby=Name#DVD%20Author] -
Have a look at the links Specialist supplies in this thread:
https://www.videohelp.com/forum/viewtopic.php?t=162538The glass is neither half-full, nor half-empty.
Thanks for the replies and suggestions! I'll give them a try and post the results.
ChachiFace -
oops
(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 15:32 -
Does Tmpgenc Authoring works 4 support motion background menus?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 10th Mar 2011, 02:35 -
extract dvd menu text & time
By msdiane in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2008, 11:25 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 07:32 -
Are there any ways to edit some text out of motion menu ?
By Hiddengibbon in forum Authoring (DVD)Replies: 3Last Post: 3rd Jun 2007, 12:07
