Im trying to convert a movie thats in Mpeg2 to SVCD after it converts it with nero I try and burn it but says its over sized, to big! What other program can I try and convert and burn it with?
Thanks!
Try TMPGEnc for converting, Nero is lousy mpeg quality. There's a guide in the convert section. After converting you can then burn with Nero in SVCD format. You may still have a problem with the size though, SVCD will typically hold anywhere from 35-60 minutes per disk. Using TMPGEnc you can create several mpegs so that your film spans several CD's.
Problem with converting MOV to MPEG2
By encAmateur in forum Video ConversionReplies: 5Last Post: 18th May 2011, 02:56 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Problem converting VOB to MPEG2 with mpeg2enc
By Massa in forum ffmpegX general discussionReplies: 3Last Post: 3rd Jan 2009, 06:51 -
Problem converting MPEG2 to FLV with MEncoder
By mspo in forum Video ConversionReplies: 2Last Post: 1st Jan 2008, 08:44 -
Strange problem converting local show to mpeg2.
By jcm0320 in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2007, 00:15
