    Mar 2003
    Columbia Tennessee
    I have a movie thats split into two mpg files. How do i connect them togeather so i can place them on a DvD to play in a dvd player
    let me know thanks in advance
  2. Member Dhruv's Avatar
    Aug 2001
    Australia
    I'm assuming that the mpegs are already DVD compliant mpegs, so all you need to do is join them and burn the DVD. (If not, take a look at the convert section).
    There are various tutorials for joining mpeg2, take a look here.
    Regards,
    I only dream in black & white...
    MSN: paschendale@gmail.com
    Mar 2003
    Columbia Tennessee
    What do i have to use to join them ??
  4. Member Dhruv's Avatar
    Aug 2001
    Australia
    Depends which guide you're using. Look here: https://www.videohelp.com/tools
