Up until 3 days ago i didnt have any problems with any codecs, could play all films no problem.
But then I needed to download codecs for my misses to play films on her laptop.
Downloaded Nimo pack 5, and was it was an updated version of the codecs I had I installed it on my pc too.
After that I can no longer play XVID's which have a framerate of 23.97, which is most of my XVID's.
I have tried uninstalling the Nimo pack and installing FDDshow and the latest XVID and DivX codecs and can still not get my files to play normal anymore.
It has gone back to playing films with a green hue and the picture being funny as if the framerate isnt keeping up and the pics are overlapping.
Can anyone offer any advice as its really starting to do my head in.
I recently had a very similair problem to you, it seems to me that the Nimo pack isn't really all that great. Anyway, here's my solution:
Download a fine program called AnalogX which allows you to see all the codecs installed and lets you remove them. Having said that, remove all the video and audio codecs (including the ones which you got seperately from the Nimo Pack) and then reboot.
Now you have two options, you can either install the codecs which you need seperately, or you can go over and download the K-Lite Codec pack from http://www.k-lite.tk (which is what I have). If you want to minimise the possibility of problems occuring then I'd suggest that you just get the codecs you require.
Best of luck,I only dream in black & white...
MSN: paschendale@gmail.com -
Thanks mate.
Installed that codec set from klite, and my system is now back to norm.
cheers dhruv. -
Where on earth did you get the impression that it was?!?it seems to me that the Nimo pack isn't really all that great.
/Mats
Xvid Sync Problem
By Peru in forum AudioReplies: 4Last Post: 21st Feb 2011, 14:15 -
Problem with convertion to xvid...
By zovx in forum Video ConversionReplies: 11Last Post: 11th Feb 2010, 08:43 -
MKVTools and Xvid problem
By Geiger9 in forum MacReplies: 5Last Post: 18th Jun 2009, 17:34 -
Problem with XVID
By s2dat in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2008, 13:25 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 05:14
