  1. Recently I bought a Capture card and it has a codec to convert MPG1-2 and few others formats. But the problem is I cannot select SVCD resolution 480x480 in my capture card. So I am looking for a conversion application which will reduce my resolution to SVCD standard.
    Thank You
  2. if you ran it thru TMPGEnc it should come out at 480x480
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You might need the mpeg2 plug-in for TMPGenc if converting from mpeg-2, it's in the Tools section.
  4. What resolutions can you capture at? Because if it can do 352x480 (CVD) I would call that good enough and be done with it.
  5. Originally Posted by ZippyP.
    I tried searching everywhere in tools section. Could you please point me to the right direction.
