Hey folks, I have a small questions.
What happens when one inserts a DVD that was authored as progressive (25fps progressive-scan PAL) into a normal PAL DVD player and attempts to watch the DVD on a PAL television (interlaced) ?
I know that for the NTSC system, you have to add 3:2 pulldown flags for the DVD player to perform 3:2 pulldown on the fly while the DVD is playing hence turning a 24fps progressive NTSC DVD into a 29.97fps interlaced NTSC image.
How does this work for PAL????
I'm in North Am. so I can't just burn a DVD and test it.
Results 1 to 1 of 1
Will a progressive scan MPEG2 work on all DVD Players?
By jnms in forum Authoring (DVD)Replies: 29Last Post: 30th Oct 2011, 16:22 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 12:52 -
Two Questions - Progressive Scan & DVCAM...
By gavfreed in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jul 2007, 11:26 -
PAL Camcorder with Progressive Scan Mode
By ropdoh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 4th Jul 2007, 07:27
