I followed this guide: https://www.videohelp.com/mpeg2tovcd.htm
I had a NTSC SVCD made by a friend, which I wanted to put on a PAL DVD. I followed the above guide and the result looked good. However it was desynched with about 20sec, that is the audio comes 20sec late. How do I fix this the easiest way?
Thanks for any help![]()
There is the possiblity that you can simply change the length of your audio to match the length of your video stream. Look for GoldWav, or some any other audio editor that will let you stretch your audio. If you do this, and it's still out of sync, then your in for a bit of hard work, as there is no easy fix. You can try to follow these instructions I posted a while back. It does work, but it's not for the squemish...
https://www.videohelp.com/forum/viewtopic.php?t=159667Impossible to see the future is. The Dark Side clouds everything...
Ripboot after conversion video & audio sync is out by 1 seconds ???
By yamyoume in forum Video ConversionReplies: 5Last Post: 17th Oct 2011, 15:32 -
Audio/Video Sync Issue with .mts File Conversion
By arturo_morosoff in forum Video ConversionReplies: 2Last Post: 4th May 2010, 10:52 -
Audio Damaged After Video Conversion. How to Fix?
By Fluoresce in forum AudioReplies: 1Last Post: 5th Aug 2008, 04:01 -
Conversion of audio to match video
By deltaromeo in forum AudioReplies: 11Last Post: 29th Jan 2008, 13:01 -
WMV video and audio slightly out of sync on conversion to AVI
By Calidore in forum Video ConversionReplies: 8Last Post: 10th Jul 2007, 09:48
