has anyone tryed the hacked firmware if so if i use it will i still be able to update it again when NEC bring the new one out thx for any help![]()
http://212.203.28.251/1300a-105hacked.rar
After a tip from YoAnn I started working on support for currently unsupported discs
I added a number of media codes (by replacing certain "future media" like RITEKG08 etc).
This needed to be done in a special way and took me quite some time. I think everyone will be pleased with the results!
My LEADDATA01 started to work (@4x without errors) with this method, so possible others will work too!
Support for the following media codes has been added:
NANYA (@2x)
LEADDATA01 (@4x)
SKC Co Ltd. (@2x)
LONGTEN TECH (@4x)
GSC001 (@2x)
UTJG01001 (@2x)
" " (6 times space) (@4x)
CMC MAG.AF01 (@4x)
Support for the following discs can be added also, but in that case I need to remove support for discs that are currently in the shops (LGE, OPTODISC, LD and TDKG010000d9 could be used for this) In case you're interested, drop me a PM with the media code you would like to add and which one to replace and mailaddress, so I can make it for you!
Possibly supported media (only on request)
INFOD K-R (@2x)
DDD (@2x)
PLASMON (@2x)
EURODIG-DISC (@2x)
You can download the new version below:
http://212.203.28.251/105x.rar
For more info about this project look at:
http://forum.rpc1.org/viewtopic.php?t=14877&start=100
You can always update with NEC firmware when NEC releases one (I wonder when that will be)
Forum hacked?
By TreeTops in forum FeedbackReplies: 42Last Post: 20th Jan 2012, 06:24 -
Can a tv re-set a region-hacked dvd player?
By Monkey69 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 6th Jun 2011, 11:21 -
U.S. Predator drones hacked with $26 software
By deadrats in forum ComputerReplies: 21Last Post: 20th Dec 2009, 10:48 -
Re NTSC TV's and hacked DVD player
By Katiemay in forum Newbie / General discussionsReplies: 65Last Post: 12th Feb 2008, 13:03 -
iPhone Hacked!
By vcdlover in forum Latest Video NewsReplies: 6Last Post: 31st Aug 2007, 15:42
