try to convert HK VCDS with two languages to do a mutli dvd, ones with only single language work ok , but when svcd2dvd gets to the dual langauge mpegs after the counter on the ms dos box finishes it dissapears never to return and nothing happens after this for ages.......
so does it mean this programme doesnt support dual langauge dual audio streams???
thanks
propluskk
AnonymousGuest
I'm afriad single audio tracks are only supported at the moment. Having said that it would be quite simple to implement - I'll put it on the list.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
Norcent DVD player, ask's for language problems...
By MagikLair in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jul 2008, 14:32 -
Dual Language Films
By Witchypoo in forum Newbie / General discussionsReplies: 6Last Post: 29th Jun 2008, 05:42 -
Converting Bi-Lingual VCDs to Single Language MPEGs
By HHBear in forum Video ConversionReplies: 3Last Post: 13th Feb 2008, 22:05 -
Help extracting language track from dual audio video.
By ebisoba in forum Video ConversionReplies: 5Last Post: 9th Sep 2007, 13:53
