Its giving me lots of problems. When I first got it nothing was working and eventually I got it to burn DVD's but whenever I try to burn audio I would get an error immediately. Now I'm having problems burning anything at all. As soon as it starts to record it immediately stops and gives me and error but nothing was written on the disc at all. I was at 1.0g firmware and I just flashed it to 2.0f and there's no improvement. Does anyone have any suggestions on what I can do?
Really could be many things.
1) What software are you using to burn ? If it is a ROXIO product then get ready to switch.
2) Do you have a valid ASPI layer ...More on this if you need help.
3) I have the 500UL and again, never a burn problem or a play problem and I have 1.0G...so it is not hardware most likely..It is software. -
I am using the version of Record Now Max that came with the writer. So do you think it could be the ASPI layer? If so I know nothing about it so you would have to help me with that. Thanks
someone please help me here ive been having problems since i got this thing in february and im about ready to throw it out the window
of you have recognize video_ts and audio_ts as dvd compliant checked in record now max then something could be wrong with your dvd structure and thus it refuses to burn. Anyhoo a description of what the error says would be helpful.
It says that there was an error recording to the disk then when you click to find out more it tells you that the disk may be dirty or corrupted etc and I know that this isn't the problem. One other question, where in my settings do I go to swith to PIO Mode etc because the last time I redid the firm ware I changed that first then did it and the burner worked fine. However, I didn't use it for about 3 weeks or so and went back to use it and got this error again which is the same as I used to get. Therefore maybe if I attempt to do this again it will work again. Thanks.
Ok well I just formatted my computer and I'm still having the same problems, same error etc. So if anyone has any input please help me. I'm pretty sure that I have to chagne the PIO/DMA settings before doing the firmware but I dont remember where that is.
I hate to say this but sony make's crap driver's just read past post people have alot of problem with SOny's DR500 if you need to buy a new drive that dual get PIONEER they make the best drive's in the world
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 14:35 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 18:45 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
