Results 1 to 30 of 36
  1. Hello everyone.
    I've looked through all of the forums related to this topic and I couldn't find an answer that would work for me. I tried using EOvideo and some other programs, but they don't work for .rmvb file. ONLY work for .rm files.
    I have so many .rmvb files that I want to convert them to .mpeg so that I could burn them onto a VCD and watch on my standalone DVD player.
    I've spent so much time search for an answer, but couldn't find one.
    I hope somone here could help me with this one...
    Thanks!
  2. What on earth is an RMVB file ? i've never heard of such extention
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. I'm not sure exactly what RMVB file is, but I believe that it is a Real Media Player file and it is different from the RM files.
  4. same here, couldn't find guides or way about converting rmvb, but I wanna convert mpeg and avi to rmvb. save space more than divx.
    RMVB = real media variable bitrate, the new kinda compression format, I think rmvb would be the next generation vedio standard
  5. You guys sure about that name ? can you give me a click to download so I can check it out ? maybe i'll find some way to convert it as well.
    Best Regards,
    Sefy Levy,
  6. Member irongang's Avatar
    Sep 2001
    Richmond, VA
    Did you try the Real7time Converter? I've had luck with that with rm files in the past. I don't know if it will work with newer formats (if you didn't guess from the name, it's a Real 7 converter). Worth a try, maybe.
  7. Could you provide a link for that program ? I couldn't find any operative links
    If it's any good and free, I could add it to the guide
    Best Regards,
    Sefy Levy,
  8. Actually I've tried using that program, but it doesn't work with .rmvb files. I think its only for .rm files.
    No luck....
  9. Originally Posted by jack078
    Standard, huh?
    Are you sure about that?
    Real Media is usually associated with the worst looking/sounding media that exists.
    What's "taters", precious?
  10. Video Restorer lordsmurf's Avatar
    Have you tried to rename it to .rm ? Then test with EOvideo or something else.
    universe
    link to real7ime convertor
    http://www.geocities.com/real7ime/
  12. It doesn't seem to work. Is there other ways of doing this?
  13. Can someone here give me a link to a file with this .rmvb extention ?
    I Can't test it unless I have a file you know
    Best Regards,
    Sefy Levy,
  14. This is a new format to me.
    At Real.com you download a Free encoder called Helix producer basic. Use this to create the .rmvb format file.
    Do not know what can read this new format other than their player.
  15. Member DJRumpy's Avatar
    Dallas, Texas
    RealVideo Variable Bit Rate File is what the extension is. There is almost nothing on the web regarding this format, other than the fact that it's Real's version of VBR encoded content. Welcome to the twentieth century
    Searches for converters turned up almost nothing. You might try here:
    http://www.parallelgraphics.com/products/moviemaker/
    It says it will convert to this format, as well as AVI, MOV, etc, so it may be able to convert FROM as well. Worth a shot anyway.
    Impossible to see the future is. The Dark Side clouds everything...
  16. Originally Posted by DJRumpy
    lol....
    I cant post the link cuz Im afraid thats kinda warez
    anyway I have tried using Real.Helix.Producer.Plus.9.01
    but when I wanted to convert avi or mpeg files to rmvb, the VBR option is non selectable (grey)
  17. Originally Posted by gilhoy
    Standard, huh?
    as far as i know, program like "Real Helix Producer" works simular with TMPGEnc, you can adjust the quality to make it as good as DIVX but have almost half the size. DVDrip usually is like 700mb but RMVB is 300-400mb.
  18. Member
    Dec 2002
    The Great Northwest
    Real Media INC. and that crook Senator Maria Cantwell both SUCK together or apart!!!!!!!!!!!!
    D
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
  19. Well, EO Video works for me. Tried several rmvb already.
    Its a little slow but convert to vcd1 mpeg perfectly with sound - so far -.
    I tried the software rm converter , it converts to avi only and then i use Tmpeg to convert to mpeg , the sound will not sync after the movie plays for 1/3 .
    I use Eovideo 1.36 30 day trial verson.
    Just rename the rmvb to rm. Eovideo will process it for you.
  20. Renaming the file doesn't work. It just add the .rm to the end of the name...
  21. Originally Posted by g2k3000_3000
    not only rename to file, you gotta change the extention, use command prompt type, rename *.rmvb *.rm
    anyway, I finally find the way to use Helix Producer to encode to VBR rmvb files [/quote]
  22. Originally Posted by jack078
    Is it possible for you to explain how you used Helix Producer to encode the rmvb files?
  23. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    g2k3000_3000
    I use Helix Producer Plus all the time and the edit gui that comes with it to cut and paste clips (remove commercials etc...). I often capture straight to rmvb and get very good quality 2 hours vids for storage on 1 700 mb cd.
    Helix will convert to rm or rmvb but not from rmvb to avi, mpeg or any other format.
    Eovideo does convert from rmvb to mpeg or avi, I have used it many times. Under the file menu there is a extension manager that allows you to add the rmvb extension so that EOvideo will be able to find the file type.
    I have had no problems converting files which I created using Helix and the rm9 codec. If you are having a problem and the source is downloaded it may be a problem with the file or you do not have the rm8 or rm9 codec on your system.
    There's not much to do but then I can't do much anyway.
  24. Originally Posted by gll99
    Have you ever came across a problem where the sound is totally off by like 2 to 3 seconds?
  25. Originally Posted by gll99
    g2k3000_3000
    exactly, I was always thinking about how to burn some tv series to fewer disc with watchable quality. until I found some info about RMVB. now I can save like 800 mins tv series to one cd, kool!!
    and yea, the RMVB movie is the same quality with DIVX while rmvb is only half the size.
  26. But the downside of the rmvb file is that you can't make a VCD out of it and you can't play in on a DVD player...
  27. Originally Posted by gll99
    g2k3000_3000
    I have used EO Video to convert rmvb. Some rmvb files work; some not.
    Does anyone know where can I find rm9 codec please?
  28. RMConverter worked for me. then the trial ran out.
  29. Hello,
    rm / rmvb to mpeg - please use EO Video, it work great
    mpeg to rm / rmvb - please use Helix Producer Plus 9
    Some Reference:
    http://hk.dir.yahoo.com/computers_and_internet/software/multimedia/video/RMVB/
    http://www.realnetworks.com/resources/howto/producer/readme_updates.html
  30. Hello,
    A remark:
    For EOvideo to successful convert mpeg to rmvb, you need to
    install RealOnePlayer 2.x (no more codec need)
    If the rmvb file can be played with RealOnePlayer, EOVideo can
    convert it, I tried many times.
