Now using TMPGEnc12a, trying to encode .avi to vcd.
First try, crashed at 6%.
Downloaded the VirtualDub 1_4_7
Saved the audio as .wav
Tried again with TMPGEnc12a
Video .avi
and
Audio .wav
Encode
Crashed at 6% Again
Please help me!!!
You didn't say what codec the avi uses. But if it's DiVX it's probably a freeze(bad) frame.
You can try to open the file in VirtualDub, and directstream copy both the audio and video. VDub will rebuild the bad frames.
You can also try AviDefreezer, which you can download on doom9.net:
http://www.doom9.org/Soft21/Files/Editing/avidefreezer.zip
if this isn't working you can also find DiVX fix on doom9.net under download --> AVI Editing tools
good luck
<font size=-1>[ This Message was edited by: Peter on 2001-09-23 08:25:13 ]</font>
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
