Does anyone have any good information on converting between PAL, and NTSC aspect ratios (specifically figuring the vertical)? From what I've found, it looks like a simple matter of multiplying the vertical by 0.9076 (.9) when converting from PAL to NTSC, or multiplying the vertical by 1.094 (1.1) when converting from NTSC to PAL.
Can anyone in PAL land verify if this is correct? This would make a 2.35 AVI, which was 720x306, approximately 720x334 for PAL? Does that sound correct?
Results 1 to 1 of 1
Impossible to see the future is. The Dark Side clouds everything...
Aspect Ratios: 0.889 vs 0.9191
By Hass860 in forum Newbie / General discussionsReplies: 15Last Post: 13th May 2010, 04:14 -
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 11th Mar 2010, 00:18 -
AviSynth & Aspect Ratios
By blazin-j in forum Newbie / General discussionsReplies: 3Last Post: 28th Nov 2008, 14:39 -
Converting to Divx and Aspect Ratios
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 28th Mar 2008, 18:43 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 16:13
