i have a iso file and i have not burned it to a dvd its pal is there a way to change the file to ntsc so i dont have to burn it first?
Convert the iso to the folder structures instead using winimage or something.
Then convert the vob's to an mpeg 2
Then convert the mpeg2 (which is still pal) to an ntsc mpeg2
Then create the dvd again using the new mpeg2 -
i have to same thing i have a PAL and i wanan change it to a NTSC. is there a easy program that i can use to do that??
Originally Posted by coyote
Where can you find winimage or "something" (what else can do this?) And are these programs freeware? -
If I strip out the movie, I can do the conversion from PAL to NTSC but how can I do this and keep the menus too?
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
