just got my hands on a "prerealese" of nero softwares new plugin for nero burner, (http://www.nero.com/en/mpeg2time.htm) and tested it with a vob file and it works. now you can drag n drop vob's directly to nero and burn it as svcd. but i would like to see a good test of the plugin. what formats can it take and how fast is it compered to other metodes of converting to svcd..
BeLLe
I'm testing the latest beta of the plugin right now(got it from Ahead). I'm using a 1 minute vob dvd sample and will compare it to cce and tmpgenc.
tried with some longer vobs (up to 5 mins) and have some problems.
1) theres no sound in any of the converted vobs
2) some of the clips aren't converted in their full length (eg. a 2 min clip only have the first 20 sec)
I dunno if i just have an erly beta or the same beta as you but it seems like some serious bugs ....
BeLLe -
belle: i got the same "problems" and it wont work with anamorphics dvds, they will be in wrong aspect ratio. I dont think it is bugs, it just dont support vob conversions just mpg2,avi. Maybe in the future though.
I used an avi source and it worked good in nero. I have made comparison chart here
http://www.vcdhelp.com/comparison.htm#mpeg2
will add pictures later.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 14:58 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10
