FAILED TO CONVERT VIDEO FILE
ERROR: 80041c21
[17002:10:0]
I get this message after the converting video bit after I set everything going.
I'm trying to convert an Mpeg2 DVD compliant file to the same only with chapters
Any thoughts? or xtra info needed?
Thx
How did you obtain your source MPEG file?
Jerry Jones
http://www.jonesgroup.net -
I converted it from .avi to a DVD compliant Mpeg file with TMPG.
What I meant to ask was 'what was the source of the original .avi?'
In other words, was this .avi file captured from a DV camcorder?
Or did it come from some other source?
Jerry Jones
So when you explain the .avi source was a 'compressed film,' you mean it did not come from a DV camcorder, right?
So the next question would be:
Do you know what the attributes of the original .avi file were?
Were they standard in any way?
In other words...
720 x 480?
24-Bits?
48khz, 16-bit audio?
etc.
What I'm suggesting is that the source file attributes are significant.
I've noticed that about 99% of the problems posted to this forum seem to be related to...
a. files 'ripped' from commercial DVDs using free ripping software;
b. files captured from proprietary hardware MPEG boards.
When I get some time, I'm going to do some analysis of these types of files to determine precisely what makes them different.
In the meantime, I used standard DV .avis just this morning to author four one-hour DVDs using DVD MovieFactory 2 - and it worked without a problem.
Jerry Jones
Hi there, this is where I'm upto.....
1. Convert the .avi with TMPG into a DVD compliant Mpeg2
2. Demux and re-name Mp2 to Mpa
3. Import these and create VOBs' in IFOedit
4. Create my DVD using Nero wizard instead of setting up manually, this seems to make a difference cos' after this my DVD seemed to play as I expected in my standalone.
I'm going to play around with the chapter creation now in IFOedit
Any tips would be appreciated..
Thx all
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 10:03 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
